It is currently Fri Aug 15, 2025 7:29 pm
PostPosted: Sat Nov 15, 2014 1:09 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So I'm about to do my first set of laminated sides using Brazilian (0.07") on the outside and mahogany (0.045") on the inside. What is your preferred glue for double sides?
Doug
PostPosted: Sat Nov 15, 2014 2:24 pm
I've used both Unibond 800 (a urea formaldehyde glue) and epoxy and prefer the epoxy. For guitar sides the West Systems is good brand and I like to add their amendment, chopped polyester fiber. It makes the glue setup a bit harder.
PostPosted: Sat Nov 15, 2014 4:32 pm
I have used both as well and am using Unibond 800 right now. Downside is that the resin has a short shelf life. I've got my latest order in the fridge but at room temp it can go bad in 6 months.
Both work but I like the way Unibond dries like glass. Hard and brittle. I think either is fine.
PostPosted: Sat Nov 15, 2014 8:11 pm
I am allergic to so many things. I wonder if anyone uses fish glue for this?
PostPosted: Sun Nov 16, 2014 7:35 am
Laminating multiple layers of thin veneers I have found that having the veneer very dry seems to create less stress in the final product, so water based glues are out for me. I use epoxy. Any "bleed through" is taken care of with an epoxy fill.
PostPosted: Sun Nov 16, 2014 9:45 am
Terence, I also liked the glassy brittleness of Uni-Bond. After comparing it to the West Systems epoxy amended with the chopped fiber, I was convinced that I could get similar results with either.
These users thanked the author Barry Daniels for the post: Terence Kennedy (Sun Nov 16, 2014 10:50 am)
PostPosted: Sun Nov 16, 2014 9:53 am
I'm currently using Titebond Extend. Longer open time, and dries hard.
PostPosted: Sun Nov 16, 2014 10:17 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/ve used the following for laminating sides, HF white glue , titebond, fish glue, system 3 epoxy minus white silica filler, and a veneer bond uf glue. I use 3 and 2 multiples of .074-80.The following are some of the variables one must pay attention to a, method of laminating, b temperature, c set up time of glues, species of wood being laminated some are easier than others e.g sycamore, and a few others. UF is my favorite in the summer when temp is close to 85 as there is about a 15 min set up time giving me plenty time to lock down clamps and check for irregularities. Your location, dry or humid environment will also determine set up times and dry time
PostPosted: Sun Nov 16, 2014 10:20 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I liked the idea of not adding any water to the sides with the many glues that do and went with West System epoxy. It set up well and I LOVE the rigidity of these double sides. This was my first but won't be my last time doing this. Thanks for all the input everyone
Doug
PostPosted: Sun Nov 16, 2014 11:01 am
Sounds great. I think you will be happy with what they do for the sound of your instruments Doug. I have certainly become a believer.
Did you buy the Brazilian as a veneer or thin a thicker piece?
PostPosted: Sun Nov 16, 2014 11:58 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I received the BRW at about 0.100" thickness.
Doug
These users thanked the author Doug Balzer for the post: Terence Kennedy (Sun Nov 16, 2014 2:36 pm)
PostPosted: Sun Nov 16, 2014 12:55 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
FWIW I/ve seen BRW veneer .022 for sale at certainly veneer in buffalo ny. Where I get all my veneers forgot the price.
PostPosted: Sun Nov 16, 2014 4:04 pm
Once I finally get set up again to start building Selmer's I plan on using fish glue. I simply love the open work time it has and it dries nice and hard. I don't think the water will matter so long as it's held in clamps long enough.
Good topic.
PostPosted: Mon Nov 24, 2014 12:38 am
I've used West Systems, fish glue and yellow glue, all with fine results. As far as bleed through goes, I just hit both non-gluing surfaces with a coat of Bullseye sealer. It doesn't stop bleed through with the more porous woods like padauk and EIR. However, it does keep the glue that does bleed through (especially West) from staining the sides. Just a quick sanding and the sides are clean.
michael propsom
www.propsomguitars.com
